Update 2.7.1 makes my renders zoom out
After installing the latest update 2.7.1 problems with my renders started.
When I want to render my scene in sketchup I press the button “render image” .Then the camera in Enscape goes back an few hundred meters and renders the shot. Not the scene that I had saved in sketchup.
Almost as if the synchronize views function doesn’t work while rendering. I only have this problem when rendering. Otherwise enscape is working fine
Can somebody help me?
I’m having the same issue as well. It looks like it’s zooming out to the same position as when I un-sync the camera view. The same thing happens when I’m using an Horizon skybox.
Tj
I am having the same issues, and it’s causing production delay!!! please help!!
Having a similar issue in the ARCHICAD version… Seemed to be coincident with the ENSCAPE SAVED VIEWS release…
Maybe Enscape can try to see if there’s any correlation
I created a THREAD in the ARCHICAD SECTION…
d.
It seems like there is a bug in the latest update.
@Enscape, please fix it.
I am running enscape on a windows 10 pc. I7 cpu and Gforce gtx 1070 ti
@twill1023 , I have a previous version running on my laptop. So I used that instead to finish my renders. May be you can do the same
Same issue. I have tried using SketchUp Scenes and setting up Enscape Views but either option leads to a zoomed out view.
Please resolve quickly!
Thank you all very much for the reports, we’ll investigate - I’ve forwarded this our developer as well.
I just updated to the latest preview version and it looks like it is still happening. (When the match view is enabled & the field of view angle does not match the SU viewport, the image in the Enscape window jumps to the FOV in the Enscape settings.) This is not happening in the 2.7.1 preview 1 (+19391)
Where on the site can I download this last clean version?
When you go to the download page - there’s a link towards the bottom for the preview releases. On the preview releases page - there’s a link for older preview versions.
You’ll also see the text “Download older versions here.” on the download page below.
I’ve also tried to reproduce this once more myself with the latest Preview 3. I was not able to reproduce this zooming out issue anymore, can you please try it with that version as well and let me know if it still doesn’t give the expected results?
Just to make sure we’re on the same page:
  1. I enable view synchro
  2. I enabled “Use Viewport Aspect Ratio” in the Capture tab of the Visual Settings
  3. I’m in perspective mode
  4. I render and image and could overlay it over the SketchUp viewport just fine, the rendering is not too far zoomed out or anything
Thank you in advance!
@andybot , even when I adjusted the FoV it was just being translated into the Enscape Visual Settings automatically. :confused: You can gladly send in a video of this behavior for example, or guide me through your exact steps again - you are also using Preview 3 I suppose when you say you have the latest installed? :slight_smile:
I just saw preview 3 posted. I’ll give it a try and see if I can do a screen vid.
Andybot, let me know what happens when you download the newest preveiw 3 version. I have a very busy day trying to finish up a project and don’t have time to experiment until later today.
I had to go back to SU 2019 and an older version of Enscape to complete a project with a looming deadline.
So it’s weird. I did a bit more testing with 2.8 preview 3, and things are not consistent. When I first opened my scene, I was able to reproduce the issue. Toggling the capture settings seems to change it to behaving normally. Not sure what to make of it, hope the developers find the issue.
Here’s my screen recording: https://www.dropbox.com/s/05jun7isund3jk2/scr_20200429112122.mp4?dl=0
Ok..Went to test now with some varied results.
When I used the "Use current Enscpae Viewport:, I got expected results; (Test 1)
When I used Select Favorites and "Enscape scene 1 (which matched the cureent Enscape Viewport), it zoomed out like before during the rendering (Test 2
Enscape…any updates?
Okay, that is more than clear @dldieterich2 and @andybot , I’m sorry that this has been influencing your workflow surely, I’ve filed a bug report now - Andybot, thank you very much for taking the time to make this video! I’ll get back to you again as soon as possible.
I am having that same issue. It is becoming very frustrating to have these cropped scenes set up to render and then the camera jumps back. My work around has been to render it larger and then manually crop in Photoshop although not ideal.
Please let me know as well if there is a fix for this.
Duane
Thank you all very much for your patience. We got this behind this problem and we have also resolved it yesterday, internally, so the fix will also be included in the next upcoming preview! That preview should also be released fairly soon, so stay tuned. :slight_smile:
Thank you!
