i noticed that using IPR uses around 30% of CPU usage, and VFB around 90-95% of CPU usage…
something special to do to get full speed in IPR ?
edit : max2020
edit : max2020
Do you mean you get different performance between Viewport IPR and IPR in the VFB?
yes exactly, in IPR 30% usage of the cpu(s), and VFB is around full CPU usage
Can you send me the scene and make a video of what exactly are you doing?
mail sent with screen captures and max2020 scene
I tried on a different workstation with simple simple teapot scene, simple hdri, in the begining the viewport ipr works fine, same speed as vfb, but then after a while turning and playing around, stopping and restarting the viewport ipr, I got the same speed slowdown. Very noticeable in the viewport display, and Cpu usage confirms the slowdown
Used cpu next update 2
Ok thanks for the report - will check it out.
It’s from the Curve CC, we are looking into it.
