Would be great if you could update the whole material library from legacy to physical materials. Yes, I know it can be done converting materials one by one or even by scene, but it would just be really nice to have them all converted from the start.
Thank you for your suggestion! We are actually planning to replace the matlib with Cosmos in V10. All materials in Cosmos will be physical materials, so you won’t need to worry about converting them.
Sounds good.
So just to clarify, will all the existing materials in the existing corona library appear in cosmos?
Currently cosmos isn’t as extensive as the material library.
The plan is to have all material library materials in Cosmos ![]()
Cheers
