Update for C4D Material
Hi!
i Have a bigger order and would like to use Vantage VR to be able to present it to customers. Until when will the new update come that the material from C4d Vray 5 in Vantage will be displayed?
We just released the build that includes Cinema 4D support. More here : Chaos Vantage v1.1.0 released - Announcements - Chaos Forum
Have in mind it’s our first public version with Cinema 4D support, so there will be stuff to fix most likely.
You shouldn’t immediately rely on it in the face of deadlines, etc.
Greetings,
Vladimir Nedev
Thank you very much
Dear Mr. Nedev!
I tested Vantage yesterday, it works quite well with the materials, when I open the project in Vantage everything looks ok as soon as I move the camera, does Vantage reflect all the objects?The whole objects then remain mirrored.the problem with the mirroring does not occur with the live link. It would also be great if you could add the Cinema 4D area and cuboid mapping!
Thank you very much
Hi!
I did a few more tests. Vray Material Coat is not transferred to Vantage either, the bump does not match either
Hm, yes, this seems to be caused by Cinema4D’s left handed coordinate system.
We will have to investigate and fix it. Thanks for the report.
There is “cubic” projection, but which one is the “area” projection ? I don’t see it in the Maxon docs.
This is not specific to Cinema 4D.
We are working on it at the moment.
It will most likely make it into the next update.
This will be difficult to solve completely due to some differences in how Vantage works compared to V-Ray.
Is the difference huge ?
Can you attach an example scene, so I can examine your specific case ?
Greetings,
Vladimir Nedev
I have projects that I wanted to present with VR is not possible because of the reflection
Do you mean the reflected/mirrored camera or the coat layer of the V-Ray material ? Which one is the show stopper or is it both ?
Greetings,
Vladimir Nedev
Ich meine die mirrored Objekte wegen des linkshändigen Koordinaten Systems.
I understand, we are working on a fix.
I will get back to you when we have something.
Greetings,
Vladimir Nedev
Thank you!
We have just released a new Vantage build ( version 1.1.1 ), where this issue should be fixed.
Greetings,
Vladimir Nedev
Thank you very much!
Hi!
That with Vantage and Cinema works great! Thanks again. Would be great if you could add the other mapping types from Cinema 4D. I noticed that when you do the live link, the Envoronmet Texture for the dome light is not transferred. s there a full screen display for the live link mode without left and right editing columns?
Can you send me a scene for this ? We have a known issue where the environment is not updated during the live link, but the initial load when you start a live link should work.
You can double-click on any of the left or right tabs and the whole vertical column will hide.
Greetings,
Vladimir Nedev
Hi Wohnraumdesign,
In addition to what Vladimir said you could also use the Ctrl+` shortcut to toggle on and off all the UI. For more shortcuts you can also check from Help menu > Mouse and keyboard shortcuts.
Alexander
We have this fixed in the build we just released - 1.2.0.
Greetings,
Vladimir Nedev
Thank you for the info
