I’m really excited to share with you this completely reworked Grass kit that works with C4D r20+ and use new Multi-instances and other powerful new tools of new Cinema 4D. Some of new features are:
3 versions in one purchase (Corona, Vray and Physical render)
New grass blades generated from geometry with much more customization
Multi-instance clones for extremely fast navigation
Deflector objects to adjust grass edges and overlaps
Possibility to change material and use it with any render engine
Container object plugin included in download
Support for Broadcast version of C4D (along with Studio version)
Sorry if this was against the rules of forum. GK v4 is new version, but actually it is really very different from previous one in many ways. If moderators think it is too much they can merge it in one thread.
Hello friends,
I’m happy to present to you a new, updated version of Grass Kit 4.5 for C4D. This update contains some very important changes and some exciting new features that will make the grass generation much easier. Here’s wants new:
New grass generation module with dynamics support
Native Multi-instance support enables millions of clones
New 3D blade profiles (flat, triangle, square, circle)
New random grass colorizer
New camera and/or distance clipping option
Corona, Vray, and Physical render support
Supports Cinema 4D R20, R21, …
This update is free for everyone who already purchased GK4, and I’ve already sent links with discount code for my gumroad store. If you did not receive it please contact me to send you your update.
How to use it in R16 visualize ? I know this is stupid question but I started as visualiser and we have only Corona in R16 Vizualize that has no mograph support. Perhaps you can generate grass easy with particle systems for poly surface.
hello! I’ve bought your grass plug in, and I’m very happy with it! now I have an inquiry, which is to render cut grass..; is it a way to have an “end” of the blades like cutted? thank you!
It is not working correctly for me in S22.
I get a large plane that cuts through my entire scene that makes it completely unusable. I have tried different camera angles and different selections but it is always there smack in the middle at a weird angle. Goes away when I delete GK 4.5 Corona from the scene. Highly disappointed.
I just bought this today hoping to make the grass more pretty and faster than my normal method and it killed me in the end, had to call a new client and beg for more time.
My fault for changing workflow at the last minute.
Sorry for the grainy image, I am so strapped for time.
