hi,
here’s the final composition
C&C are welcome!!
hi,
C&C are welcome!!
Re: updated -schematic (residential)
Those shadows look much better. You could now try to soften them a little by increasing the sun size multiplier to about 3. I suggest toning down the intensity of the car and the violet flowers. Also try ‘Michas grass’ technique to get better grass effect. Need to look at those people - the lighting on them doesn’t match the scene - this is often tricky to get right.
I like the window reflections.
What is the balcony material?
Good Luck
David
Thanks so much for the comments. Regarding the window reflection, i got it from the BILLBOARD thingy, which you have advised, hehehe. About the balcony material, it’s a glazed-like glass. Anyway, I was wondering, where I can find the “sun size multiplier”? I’m a bit lost on this.
environment - GI(skylight) - sky (size multiplier)=3
also
Good Luck
David
thanks so much david, thanks for all the help. ![]()
