UPDATEproposed interior formal living rm
sorry guys if there is no furnitures … bec. the most important thing they want to see is the floor design …ill post soon a complete render after the revisions… this is only the preliminary design…
cheers jds
Re: proposed interior formal living rm
impressive! beautiful lighting, model, view, everything!
at first sight i thought the horizon line was a bit high,
but then i saw that plant, so i noticed there are some
stairs that cant be seen. amazing render.
cheers!
Jeff, this is sick man!!!
Stunning render, like always!
CONGRATULATIONS :slight_smile:
yes nektares you noticed it.. there is 4 step stair but its not seen from the camera and unfortunately also the exterior arc is not seen too only the shadows shows that there is massive arc outside ;D
Jeff
Beautiful work, as always.
Can you tell us a little about the process. Is the floor design prepared by a floor designer? Is it one big bitmap?
Nice one!
David
the floor is just a bitmap design in cadd and mapping in ps after that transfered in su in the same scale… yup there is a designer for the floor but still i am the one revising it directly in su.. how? xplode the image create rectangle at the portion of the image and use positioning to move the marble material that you like to erase or change.. even the resolution is low it doesnt matter as long as it has the right reflection the render will still be fine…everything is modeled in su so the mesh is low… i need to trace 3ds of max creating my own using su.. as much as possible to make my models in su file…the lower the file size the better
update
photo realistic - amazing work
Re: UPDATEproposed interior formal living rm
impressive details bro!
how did you make the gargoyles/sculptures?
marvelous!
hey you are the stucco master! though i like the simple things i cant help admiring your modeling… modelling? my english is not very good ok.. admiring your skills, how did u managed that gothic vitral effect on the doors? i like the first image the best, but the second one is great too!
thanks guys… all here are modeled in su except the angel boys and the lady… thats the only 3ds here… it took me 4hrs modelling all of this stuff inside the most diddicult is the column where i done 3 patterns but this is the most attractive… about the door its only jpeg rendered with reflection.
modelling tip: always used a jpeg pattern converted in a cadd file then import in su…converter can be downloaded in the internet even its only a trial … the image must be b&w
regards jds…
WOWOWOWOW. simply oustanding. ikampay mo pa pre. “Viva Pinoys”
