Maybe i am not seeing it, but is there a way to only reload the bitmaps in vantage ? I mean if i change a texture in photoshop and comes back in Vantage. At the moment it doesnt update in vantage unless i reload the entire scene (and in direct linkmode it also doesnt work)
No, currently this is not detected, but if you are using live link you should be able to force the bitmap to reload if you set the material to use some other bitmap and then set the changed bitmap again. However I think this will only work if the bitmap is not used in multiple places (otherwise you’d have to remove it from each one first, which is too cumbersome).
