I have a scene I’m working on that takes 40 seconds to render normally, but when I turn on motion blur on the physical camera, the render nearly gets stuck on “Updating Instances”. I let it go and after 30 minutes I gave up. I have the same objects in a different file with motion blur and I don’t have that problem. I’ve searched but haven’t found a solution. I restarted max and I have no displacement modifier in the scene.
I’m using Max 2019 with the vray_adv_62007_max2019_x64 nightly stable build.
Does anyone else have this issue?
