nirsul
October 29, 2011, 11:35am
1
Hi all
I just upgraded my main machine to Windows 7 (I7 CPU) and render nodes render empty buckets.
(If I use a map which is on the nodes in a fixed folder than all is good.)
I created a UNC path for my textures folder and also forced the firewall to recognize Vray as legitimate.
I ran out of ideas.
Can anyone suggest ?
Nir
Does nodes have access to ur textures?
Can u access the driver from node ?
nirsul
October 29, 2011, 3:24pm
3
Nodes do not see my \\server\folder - this is the problem.
(at least not at render time)
Great - now u know whats wrong Fix should be easy…
nirsul
October 29, 2011, 6:32pm
5
Actully this is the problem since I don’t know why they do not recognize a UNC path.
How do you check to see if they see it (other than rendering it) ???
Go to slave, use 2x on my computer and go see if u can access ur hard drive.
nirsul
October 29, 2011, 8:26pm
7
SOLVED
Did what you said earlier - I checked why I couldn;t access the PC form the slave and then tweaked all sortso things to make it accessible
(too many for me to remember)
NIR
