What I have so far is the DS918+ and Zenith Extreme Motherboard which came packaged with a 10GbE card (RJ45) and the ASUS DSL-AC68U modem/router.
To get 10GbE, I might just have to sell the DS918+ and opt for the DS1517+ 8GB model (found here on senetic)
I’m just setup on one workstation currently and was hoping to delve into the land of fast 10GbE.
I unknowingly didn’t really know the benefits of having a 10GbE before I bought the DS918+.
The reason for the NAS is just to have one accessible place to grab work files from anywhere when I need too and store all my other personal files. But having the luxury to edit directly from the NAS would be great.
Q’s.
What do I need for 10GbE connection directly to the NAS apart from the 10GbE network interface for the NAS to connect to my PC which has the RJ45 10gbe card? My router is the dsl-ac68u (1900 mbps).
Will the router do? Or does that need upgrading too?
Is there another way to skin this cat?
Any expertise on this subject would be great, thanks.
While all the network cards are made by either Intel or Aquantia I would rather buy one directly from Intel than the Dell branded ones. They cost the same on ebay, or just tiny bit difference.
Make sure you buy one with RJ45 lan port, not the SFP+ ones.
The Asus is good enough as long as you only need two 10 10gbit ports (one will got to the NAS, one to your workstation, other devises will connect at 1gbit).
CAT5e is good enough for 10gbit up to 50 +/- meters.
1,2) I would check with Synology if the adapter will work. As i understand you already have 10gb for your workstation. Of course Synology will try to sell their branded adapters for 3x the price but Juraj is right - all adapters pretty much the same. Check the synology forum to see what adapters are tested by the users.
3) 1 is enough.
4) Cat 5e will work if they not too long. Or just get Cat7 on amazon, prices are not that high.
That switch you found will work great if you’re sure you will have only one 10gb workstation. All the nodes will get 1gb which is enough to transfer scenes and assets.
The newer TIA approved successor is actually CAT6A, which I would suggest because it’s compatible with every 10gbit device, unlike Cat7 whose GigaGate45 (GG45) connectors might cause some backwards compatibility issues.
Sorry for the late reply but I’ve having outrageous trouble backing up to an external drive connected via USB3.0 using the so called Hyper Backup app of Snologys with version history (Long thread about it here). So far, 4TB has taken 4 days. Still at 92%. I’m also gone 92% crazy with it! Renaming the app to ‘Sammy the slug Backup’ would be more apt.
But, I digress.
I’m just not sure if the NAS running in Snologys proprietary RAID SHR would take advantage of 10GbE.
Don’t get me started on the HyperBackup. I tried it when I first bought my first Synology NAS and I was literally shocked how sluggish it is.
I now back-up using (paid) SyncBreeze which can be configured from super-simple to ultra-complex. It is incredibly fast. Like billion times faster I am not kidding.
It’s able to search my 4TB SSD drives full of projects and assets within like 2 minutes. Then back-up using 100perc. of the speed of drive.
Thunderbolt NAS are waste unless you connect them directly to your Workstation, in which case you might as well install those drives locally on your workstation.
The moment you want fast, large capacity and expandable to 10gbe NAS, it gets so expensive it’s actually cheaper to build a regular PC as file-server.
If full-on file-server is too complex, one can still install some linux-distro like FreeNas on it instead of Windows, but I run Windows on it instead.
The Irish meaning of the word is quite different to other countries.
So that SyncBreeze is an app available in DSM? I’ve had to step away from the PC in case I break something up.
I will be connecting directly to my workstation. AFAIK thunderbolt is daisychannable so if I attach a laptop to a hub or to the spare TB 3 I/O in the QNAP it’ll be very handy.
That qnap also has a ready installed 10G NIC. So it has options.
Would RAID 10 be the choice for the fastest read/writes? I’ve 4 x 10tb hard drives so 3 can be redundant.
I’ve thought about it and decided to scrap the idea of 10GbE for now as I’ve only one workstation and the benifits far outway the cost.
So, I’ve got an existing 1TB 960Pro here (need 2TB) so might just get another and put them in RAID 0 and be done with it. Which will blow any other type setup out of the water.
And, use that as a work drive along with windows backup with file versioning enabled to do 15-min interval backups to the 1GbE connection to the NAS. And weekly backups to the external offsite device.
Doing those frequent backups won’t bare the system down too much.
I just got to look at the performance gain for NVMe in RAID 0. But it’ll far outway anything a 10GbE could do.
My network drives are PCI-E Intel P3600 2TB each, so the 10gbit does actually bottleneck them in continual write/read speeds :- ) but I barely ever do that. It caps at 1200 MB/s +/-.
That’s still good
Having these in these setup it’s the CPU and RAM freq. that’s the bottleneck. With overclocking to 4GHz you can get past 7GB/Sec read but similar writes.
My setup with this test was using stock threadripper 1950x [not overclocked, yet but will do eventually] and 128GB RAM @ 2,800MHz.
Just hijacking this thread! I’m thinking about getting the DS1817+ with a 10gb card and 8 port 10gb unmanaged switch. I have recently bought 4x4gb iron wolf dives for my existing nas which is purely a back up drive with versioning. I thought I’d be able to use those drives and get 4 more of the same and run a raid 10 setup with 2 disk redundancy. But I have just checked them and they are only the 5900rpm flavour not 7200. Do you think this will make a big difference in that raid 10 setup for seak times which is important for tracking all those textures down? I would rather bite the bullet and buy some new larger capacity faster drives if it is going to make the difference but it’s probably going to cost a good £600+ to do that on top of everything else. So don’t want to do that if it’s a waste.
Also am I likely to see speeds that are faster than my middle of the road ssd with this setup?
Finally do you know if it’s possible to make a drive letter on the nas so it looks exactly like a local drive? I’ve got many materials all over the shop which have direct paths set to my texture ssd and it would be a nightmare to lose all those?
I’ve ended up getting a 10g switch anyway in conjunction with 2 nvmes in raid0.
I installed the 4 drives into the new one using snologys online tut on it no problem. Took half an hour.
Then installed the extra drive. So far it’s taken 6 days to do 70% on a volume parity consistency. So, I’ve not been able to install the 10g setup. I was getting 120mb on the old 1g setup.
As far as searching files. Windows is slow compared to using freecommder explorer SW even when you uncheck search file contents. I bought the donor version of freecommder which is x64 and very good.
You cannot index a NAS like your internal drives. I’ve seen workarounds but yet to try them out.
Yes, mapping the drive is the same as usual. Assign Z as this is the most common server/NAS drive letter. Up to you though.
Will post back when I get the WR speeds and what searching is like when this parity finishes. (pulls out hair)
