Sorry but this is urgent and I need a fix now.
Came in this morning, started the computer Dell xp 64bit Vray2. max 2011.
Loaded the vray licence server as normal.
started max and all the plugins won’t load
error loading DLL <C:\ programme files\autidesk\3D max 2011\plugins\vrayplugins\hairvrobj2011.dlo. fialed to initalize
error code 126
I am screwed if I can not get this fixed now, i have a deadline today.
Help would be parreciated.
Found this on Evermotion site .
thank god and it worked. The solution is to re order the plugin files in 3dsmax plugins folder. Switching the files that live in the vrayplugins folder with the two vray files that live out side the vrayplugins folder.
Which means that the order in the plugin ini is wrong hence the exchanging of the files fixes it. The better solution would have been to fix the plugin.ini for various reasons.
One thing that can break the plugin.ini is installation of any plugin (or vray)
