Urgent problem: There seems to be a bubbly effect in my renders.
My renders are not getting tight. There seems to be a bubbly effect in my renders on the floor and the chairs. Does anyone know how to solve this?
Many thanks :slight_smile:
Marith
Hey @Marith_Thies , I can see you are making use of emissive surfaces for your lighting which is known to cause these sorts of “fireflys” and some grain. If you light the scene with “real” lights through our Enscape Objects, this behavior should be lessened or disappear entirely even when you keep some emissive materials in your scene.
Hi Demian,
Thank you so much for you help!
Only the spots are emmisive. But I will also adapt this to real lighting of Enscape objects. Hopefully this helps.
Is this a new error from Enscape? Because normally I have no problems with emmisive lighting.
@Marith_Thies , it’s not new behavior, and usually occurs when most of the scene is only lit up by emissive lighting. It cannot hurt to also make sure that you’re using our latest release as well by the way.
