I’ll check as soon as possible on our end - meanwhile could you please go to the Houdini installation folder, which by default should be in:
cd /opt/hfs18.5.351
To initialzie the environment for the opened terminal so Houdini can find all dependencies, you should then:
source houdini_setup
You can then call:
hython
At this point you should be in a hython session.
You can open your file with
hou.hipFile.load(“/path/to/file”)
You can then attempt to render one of the V-Ray Renderer ROPs by (assuming the node is in /out and the name is Perpetuel_H0042:
hou.node(‘/out/Perpetuel_H0042’).render()
Does that work ? Are the same error messages about incorrect permissions still present ?
Could you also please try exporting a simple cube as an alembic to the exact same path ( of course, replace .EXR with .abc):
