Hello
if someone can help me here - I am working on a material creation tutorial - using Noise B to control a Blend - tutorial is using Vray 3.6 for sketchup - calls for ‘Use 3D Mapping’ to be engaged as a parameter for Noise B - this setting does not exist in Vray Next for sketchup - can someone explain how to achieve this or what is substitute in Vray Next
thank you very much for your help
Thank you Slavcho
This was the setting I ended up using as it allowed for the other parameters ( ex. size) to most closely follow those form the tutorial - as there are many settings cumulatively effecting results, it is tough to know what might be causing an unexpected effect sometimes as a beginner - so I thank you for your help to confirm this setting - I will pass this info on
what threw me off my confidence with the ‘3D( Object Space)’ setting is that in my ME preview the texture appears to have a distortion when this setting is chosen ( same with 3D(World Space) - in the tutorial I was following ( vray 3.6) the 3D Mapping setting looks more like your reference above - ie preview does not show this distortion
can u speak to why I am seeing this distortion of the Noise Map in the ME Preview ?
Ah ha - I feel silly for not having seen that
- and I do notice now that some types of textures display in 3D Object space with a more flat 2D map preview - thanks for further explaining this - I hope it helps others as well
