Vary has a texture preview feature, Use full resolution, its very handy for modeling over pdfs.
What is the equal in Corona Render?
Thank you
Philip
Thank you
Philip
Can somebody answer this.
This is why I don’t put the queries int the general forum, they never get enough traffic to get an answer…
there is no comparable feature in Corona. You have to increase the resolution for all bitmaps in the scene. However, you can do this separately for native Max bitmaps and for Corona bitmaps in the Viewport configuration: Max bitmaps use the “Texture Maps” value, Corona bitmaps use the “Baked Procedural Maps” value.
Good Luck
Thank you, yes i have brought up the res.
Can you explain the difference please for general knowledge purposes.
Phil
Well, vray obviously can do it. The Max restriction is just the maximum size of 16k afaik.
Not sure what you mean here, it’s just as documented (Help). I cannot tell you why CoronaBitmaps are treated like procedural maps, could only guess ![]()
Good Luck
Isn’t it 8K? I have set it at 8K and the quality is still quite shitty, probably because they use the cheapest filtering there is.
Tested quickly a 11k JPG, my findings:
Difference between 8k and 16k settings for “Bitmaps” using 3ds Max bitmap: None
Difference between 8k and 16k settings for “Procedural maps” using Corona bitmap: Very noticeable
So it looks to me as if the 3ds Max bitmap node is limited to those 8k you mentioned (?). Corona bitmap seems to go higher (and generally looks better in the viewport anyway). But as you said, could be filtering only.
Good Luck
Interesting findings. The only problem is that i need high resolution textures in viewports only for blueprints when i’m doing modeling, but that’s when my renderer is set to scanline and using Corona bitmaps would be pretty inconvenient.
As workaround, I use regular bitmap node for blueprints, because I could find any solution with CoronaBitmap…
A workaround what for?
Good Luck
as a workaround for a particular texture that I want to be displayed sharply in the viewport.
Please log your feature request on our Ideas Portal: https://chaoscorona.ideas.aha.io/
You will need to pick “Add a new idea” and describe your feature request in detail.
For more information, please see:
Corona for 3ds Max - https://forum.corona-renderer.com/ The new way to let us know of feature requests - the Ideas Portal!
Corona for Cinema 4D - https://forum.corona-renderer.com/ The new way to let us know of feature requests - the Ideas Portal!
