'Use Photographic Exposure' in Team Render bug
When rendering locally using ‘Use Photographic Exposure’ in the camera overide, everything renders as planned. When we then ‘Team Render to Picture Viewer’ the render return very dark. I discovered that the camera overide no longer works and the camera settings are being determined by the values in the main ‘render settings’ dialogue, rather then being taken from the camera. If we match the values in the ‘render settings’, the render then appears correct.
This only happens when using Team Render in conjunction with photographic exposure. The regular EV works just fine. So I can only assume this is a bug?
Hi!
I can’t replicate this here, using only Windows machines. Perhaps also see https://forum.corona-renderer.com/index.php?topic=23429, there might be the same issue happening regarding Macs and where the exposure values are taken from.
Are there any Windows machines being used as a TR client, or only Macs?
I’ll create a test scene and upload when I get a minute.
We only use Macs. They’re all pretty much identical too.
TY, the scene would be helpful! Be sure to add the link to this thread in the info when uploading the scene (if you are uploading it via our private uploader).
