Can I use my precalced GI that was for a 8000X4000 spherical 360, to render normal views at 3500 X 2000 and just set GI calc for this to “add to current map”? (the current map being the one that was used for the 360)
I’m thinking this should speed up my normal view GI calculation. Am I correct in this thinking?
Hi. According my experience with this, the answer is YES, it will speed up the rendering and IR calculation for still shots, but you can’t rely only on the spherical IR pass to fill the entire possible views.. anyway, you can always load and inspect the integrity of IR map with Irradiance map viewer tool, or merge the data from other cameras manually instead of using “add to current map”..
Notice: You will have to un-tick “Store direct light” in LC calculation Rollout in order to store the LC into the IR map. This will ignore the need to save and load LC map for any camera view, offcourse if you use BF this is not needed..
