Hi, I have a problem with userFloat, actually with bringing attribute to shading tree. A strange things are happening. It does not have to bee float, the same happens with userColor.
I’ve created random color attribute per element, because I wanted to randomly change saturation/gain on different elements.
This is the render I have:
When I bring userFloat to shader tree, and try to controll anything with it, I got this result:
Even when I disconnect userFloat from any node, and just leave it in material builder, strange things are still happening. This is the render with disconnected userFloat:
docaml, I don’t see any big issues with the scene, all attributes are read correctly, could you pls explain which different result do you expect? However:
1. Toy instances are not packed to triplanar is calculated to the whole mesh - not particular objects. May be use “pack and instance”?
2. Triplanar ref. space. is set to reference transform, but no object is selected to provide this transform. Switch back to local object or select some object.
