Using Anima scenarios other than live-link
Hi, is there any other way of using Anima in Vantage rather than through live link from 3ds max?
Live link works ok, although using live link doesn’t allow us to queue jobs and is eating more resources than it could (renders take longer, as max is taking long time to update viewport between frames, bigger scenes are hard to launch etc)
We’ve tried .vrscene export from 3ds max but characters come in without animations. (they would move on the path, but without character moving their legs/arms, they would just slide, see viewport recording below).
We cannot try export from Anima standalone as the assets we’re using are under Anima All subscribtion.
Thanks​
Hi inkettle,
You have to use the “Update textures and animated meshes for the current frame” button on the right side of the time line when you are in interactive mode(or use the shortcut U). When you render high quality the frame is updated automatically. We have it in the TO DO list to improve this behavior. Please tell me if this works for you?
Best regards
Alexander
HI Alexander,
This works indeed, many thanks for prompt response!
Cheers, Michal
