Using Color Correction to adjust material color - How to get desired color using Hue/Saturation/Hue Tint/Hue Strength settings?
Sorry if this is too basic to ask. I am a beginner and get lost.
I understand that if a material color is not set in diffuse slot directly, I can use wrap-in color correction and adjust base color there. However, unlike other color picker dialog where I can input RGB value or select from color wheel directly, there is only Hue/Saturation/HueTint/Tint Strength settings. It seems to be a guessing game on what colors I can achieve by using these knobs. e.g. I have problem getting pure white or pure black. Wonder if there is a way to input from the “normal” color picker here? Or there is a way to translate RGB to these H/S/HT/TS values?
Tutorial/documentation sharing the secret of using these knobs would be very helpful. Thanks.
In my opinion, nothing is too basic to ask, so you’re good there - we were all beginners once (some of us even before the internet, when there was no help whatsoever :stuck_out_tongue: )
From my experience it’s just annoying/fiddly unless it’s a quite simple cc you need.
You’re better off, plus it’s mostly unarguably quicker, to do it in Photoshop or similar.
I’m not quite sure what you mean by ‘getting pure black or white’ so maybe you can elaborate?
hi, thank you for the reply and kind words :slight_smile:
for example, I add VR’s built-in material “Leather_J01_Red_12cm” and try to change the red color to, say, white. Since this material doesn’t set color in diffuse slot directly (in fact, I don’t know where the original red color was set), I do this: diffuse->wrap-in->color correction. Then try to set color correction to “white”. If there is a RGB input I can simply type in R=235; G=235; B=235 to get white color. However, I get below screen, which allows me to adjust Hue/Saturation/Hue Tint/Tint Strength only. Adjusting the Hue slider from -180 to 180 (the max range) gives me colors from green to blue to purple to magenta then back to purple, blue, green, but it never gets to white. Changing the other settings don’t seem to help. Is there a formula/look up table to translate RGB value to these Hue/Saturation/Hue Tint/Tint Strength values? Thanks again.
oh sorry, forget to say: I don’t have photoshop. It’s another expensive software to own :frowning: and I haven’t learnt how to use it. Am trying to do everything in SU & VR for now.
You don’t need Photoshop, just get Gimp, which is free, or another open source freebie.
You will need to learn something eventually, in order to do many things in post :slight_smile:
I don’t use SU so that cc is a little different but for example, to turn this red to white you will need to take down the saturation to remove all colour and then adjust the brightness/contrast to your liking.
To change colour to a different colour is simply a mix of the hue shift plus saturation/brightness/contrast. Tint is useful but can be quite subtle.
To my knowledge there is no table of values, as the change is very subjective.
I see, I am able to get white color by setting Saturation to -1 and Brightness to 1. thank you!
Will keep Photoshop and Gimp in mind to be something to tackle next. Really appreciate the guidance.
No problem, glad you got what you need.
Photoshop/general compositing/cc etc. skills are a bit crucial for cg, as you can fix or change many things later that would eat up time trying to do all in 3D,
at least until you figure out a perfect workflow for using exactly what you get from the frame buffer - and mistakes usually happen regardless :stuck_out_tongue:
