using corona passes in nuke
hello guys i hope you are doing well. I have a problem with the corona zdeph and corona velocity pass I can’t use them well on Nuke, someone could help me solve this problem or give me a link to support it I tried everything but without success .
Thank you for your kind understanding.
I am afraid “can’t use them well” is not a good enough description to understand what kind of problem you are having. Could you please at least show some screenshots / renders demonstrating what you are dealing with?
ok attached a capture of my nuke scene
Sorry, but honestly I am still not sure what I am looking at. Can you explain what the problem is?
Maybe these two will help?
  1. https://www.youtube.com/watch?v=6Hk2jhbQTuI
  2. https://www.youtube.com/watch?v=__Pm8OgxA6I
You are using the Zdefocus node incorrectly. The ‘filter’ input is the shape that the defocus areas convolve to, not the input of the depth pass. You need to channel in the ZDepth pass into the ‘depth’ channel. It is also a good idea to dilate the aliased zdepth pass by 1 to 2 pixels to avoid edge artefacts.
