it would be great if we could also use CoronaSelector maps in the Scene Environments slots. For example, if I show a building from two different views, I usually need two separate HDRI/CoronaSky settings. If you then combine this with completely different lighting setups (and also different test scenarios), it can become confusing in the material editor. I currently collect all the maps I use in a separate tab in the slate editor and name them. Depending on the project, I can end up with ~20 maps flying around in the editor.
CoronaSelector Map would help me a lot to have the chaos under control. In the end, I would only have to change the setting on the selector itself and that’s it.
Hi, I don’t know if I understood correctly what you mean, but if you want to use a CoronaSelect map in the Scene Environment slots it is already possible to do so.
I have attached a screenshot with the setup of several HDRIs and also the volume material. Changing the map selection in one of the slots automatically updates all the other selections.
