Using IR Map from Cancelled Render
If I cancel a rendering half way thru its 3rd pass on IR calcs, can I hit save on the IR map rollout and then use that saved map to render with?
Yes, you can do that.
Thanks vlado. I did try and use it, and it did seem to work well. That is a huge lifesaver for having to cut a rendering shorter for a deadline!
