When working on architectural renderings, I usually place multiple V-Ray Dome Lights in the scene, each with a different HDRI map.
Some are configured to be invisible to lighting and used only as a background, while others are set to be invisible to the camera but contribute to reflections or highlights.
Sometimes, I use two V-Ray Dome Lights with HDRIs set to be visible, allowing them to blend naturally in the render and create a new combined sky effect.
However, in Vantage, it seems that only one Dome Light is supported at a time. Although there’s a Background option in the panel to switch the environment, it doesn’t achieve the same effect I can get in V-Ray.
Is there a way to use multiple V-Ray Dome Lights in Vantage, and to control their visibility and contribution just like in V-Ray?
