I’m currently setting up in a number of vegetation models with lots of different bitmap textures, and I’ve noticed that when I drag and drop image textures from file explorer into the node editor, it will create a regular C4D bitmap shader (not a corona bitmap). Is it worth it to change the nodes to corona bitmaps?
Searching through the forums, it seems the corona bitmaps can be more prone to bugs, however in the help center it mentions that corona bitmaps help with rendering speeds. Some clarification would be helpful.
