I have a question on using Corona with Rebus Render Farm. Does it work ok? Is there any problems or settings I should be aware of? This is the first animation job I will use Corona with. In the past I have sent jobs using the Physical render engine without GI but using AO. Any help would be appreciated as I am a bit nervous Thanks John
I can’t stress this enough but… DO TEST RENDERS FIRST!
Generally my experience was fairly pleasant and straightforward. Sometimes something gets out of whack if you use different plugins or Corona / RebusFarm just goes random. Luckily the helpdesk is quite helpful imho.
I would really like to stress to do test renders, at least a couple of frames. I suspect LightMix might be problematic and there can also be a difference if you are used to saving from the VFB directly.
Oh and do make sure you are running the EXACT same version as they are running. Otherwise you might be in for an unpleasant treat.
Thanks for you reply. I am using the latest build. What version did you use for Rebus? Can I install another or older version and send it to Rebus? I am not using any fancy multi passes. Probably only z-depth for DOF. Thanks again for your help John.
Hey man, sorry for the late reply Actually, back then it was Beta 1 or even one of the older Alphas. If it doesn’t say which version they have on their website then shoot them an email, I’m sure they’ll be happy to respond
I decided to go with Ranch Computing. They are in my opinion much bette and support Corona with the latest build and R20. Excellent customer service as well. The job got done without a hitch. Thanks guys for you input John.
