Using Scene assembly
Hi folks.
Having an issue where I cant seem to render out Allembic objects when used in conjunction with scene assembly.
If I bring in the Allembic on its own it renders fine, but I need to switch from proxys to allembic to test render animations for client preview.
I have to switch everything to bounding box for now but really wanted to render the cache data to get the details.
There is a VRay attributes node but does this connect to the definition node or reference node?
Is this supported in VRay 3.5?
Currently it is not possible to render cache using the Scene assembly in Maya.
This feature has been reported in our system as a request and it will be most probably implemented in future versions. We will update this topic as soon as we any news.
Thats great news, thanks. It was a bit of an oversight on our part as we built a transformer type creature made up of client electrical products.
Sent it over to Zync render farm and couldnt render it out, not supported so had to rebuild the whole thing just using proxys!!
