Using VFB in Composite mode makes my image darker
I’ve got a very simple setup in the VFB where I use “Composite” to layer just 2 render elements - RGB color and VrayDenoiser. Both using “Normal” blending mode. When I render an image from scratch (all render channels cleared with “Clear image”, the rendered image is substantially darker than it should be. If I turn on and off any of the Composite layers, the exposure becomes correct again. This happens with the CPU engine as well, if I remember correctly. Am I doing something wrong?
Attached below is a video I recorded that hopefully demonstrates this clearly.
v-ray_VFB_composite_dark_image.zip (1020 KB)
Don’t add the denoiser to the composite, only RGB.
what if you wanted to just denoise certain areas, using a mask?
You can add masks to the denoiser layer.
That was it! Thanks!
