I’ve recently switched from form-z to rhino and v-ray. In form-z I could create a section perspective where the camera would cut through the model but still render what was behind in any reflective surfaces. is there any way to create this effect with Vray? when I use the clipping plane in rhino, Vray ignores it and shows me the back of what every I clipped. Is there anyway around this without actually cutting the model?
Not yet. We hope for the new version that will be connected with the SectionTools.
If you want you can use a double sided material to see inside a wall
