I scaled the size and shape of a vray rectangle light but my TD is concerned this could cause those lights not to work physically accurately. He thinks I might need to use the U Size and V Size in the attribEditor of the lights ‘basic parameters’ . Should they be scaled, or use the U and V size or does it not matter?
Funny, I was recently thinking about posting on this exact topic! I read that scaling lights can create a lot of noise, compared to sizing in the light attributes.
I’ve personally moved to using that method, but was more wondering if it was worth the effort to modify previous projects that get revisited now and then.
While it seems intuitive that non-uniform scaling of spherical lights won’t work properly, it might be good to mention that scaling of lights is not recommended/unpredictable in the VRay docs, as I think most people would assume scaling the Rect lights is OK. Just a thought!
