using the official release…
I have a problem to create proper UV-Tags.
When generating an UV Tag the texture gets a wrong scale.
I tried it with an C4D Material. There it works…
Am I doing something wrong, or could this still be a bug?
I had the same behaviour with the beta.
Thank you!!
When I change the order of The UV-Tag, after generating it, it works.
Found out by accident.
So, as it is only for me weird, I guess this should be the workflow?
Edit: Please forget this one, it worked only by accident…
Hi, does anybody agree on issues with uv’s or am I the only one?
@ CG: Any Ideas when you add some of the missing features to this chargeable official release?
And with which priority?
Thanks!
Hi ! You’re not the only one ! And i also have some issues with the material tag when it is not UVW Mapping projection.The render is not correct.
This seems to be a bug. I have logged in our internal bug-tracking system (bug ID: VC4D-752). I will let you know when we have updates on that.
Seems it is fixed in the last nightly build, thank you
As you already mentioned this was fixed in the latest stable build. You can download it from here:
Yes, one of many things, thank you!
Any Idea about new fixes or features?
The stable builds are updated regularly with bug fixes and small feature updates. We will let you know if a particular bug which you reported is fixed.
I can see so much clearer now…
