Hello!
I want to Uvw-map a spline with a sweep on it. Is there a way to make the uvws to follow the splines direction?
Talking 3ds max now.
Hello!
Tick “Gen. Mapping Coords.” in sweep parameters. If you have hard corners, you may have to add helper vertices near the corners to have it properly mapped (or enter a very small corner radius in case of a native rectangle).
Good Luck
Thanks!
It seemsto work well on sweep with large corner radius, but with sharp corner it fuck up the uvws totally!
