UVW Placement
Hi im trying to use the UVW Randomizer which should be able in Vray5 for Rhino. I found the UVW Placement texture but can anyone tell me how i can make it work? Thanks alot! Cheers, Felix
Hi @felix_landwehr
To apply the UVW Placement Texture to a bitmap, you will need to choose Type: Mapping Source and select UVW Placement in the UV Placement Source. I’ve prepared a short gif for better visual understanding: http://ftp.chaosgroup.com/support/screenshots/2020-12-29\_09-16-28.gif
From there, you can adjust the placement settings as you wish.
You can find more information on the Randomization Parameters (as well as some great visual examples) here: V-Ray for Rhino
Hi Nikoleta,
thanks a lot!! Exactly what i needed :wink:
Cheers, Felix
