I have a problem with the rotation setting in the UVW Placement/Randomization tab.
It says in the documentation “UV Rotation - Controls the UV rotation variance range in degrees.”
Except that in my case when I move the cursor over the parameter it says “Min:-1000000 Max:1000000”
I can’t get a texture to rotate 360° with a 90° step.
Can someone explain me how to do that ?
Thank you.
Enter 4 as a step. This actually will divide the 360 (full circle / default value ) into 4 steps meaning 90 degrees.
Please try that and let me know if it worked.
It is in your current workflow that you have to make a calculation (360/90=4)
When it would be simpler to say that I want a rotation from 0 to 360 degrees with a step of 90
Example: If I want to make a random rotation by steps of 15°, with your current workflow I must calculate (360/15=24).
With my logic, I enter 15 in the “step” dialog box.
