Hello, I have a problem when I am using the UVW randomizer. I create a new material, select the UVW Ran. in the diffuse channel, click into the randomizer, set a picture into the texture channel, switch to stochastic Tiling and like to go back, then Cinema crash’s. Always… ? Using Win 10 R25 latest Vray… Do you have an idea what’s wrong? Thanks in advance…
Hello @haniel1107 ,
I regret to hear that you experience those issues.
I followed your steps but was not able to reproduce the crash on my end. Would you mind recording a short video, demonstrating the crash and sending it to us? Also, can you go to the _bugreports folder in your preferences folder and send us the files if there are any? Can you generate a crash dump file and send it to us as well? You can find the steps on how to do that here.
Lastly, are you using the latest official V-Ray build or do you have the latest stable build installed? Thank you.
Hello @aleksandar.kasabov thanks for your reply and testing it out. I am right now rendering something, but then I will try to reproduce it with a short video..
And yes the latest build… Thanks
