UVW randomizer problem with instances
hi,
I have a problem with the UVW randomizer. I noticed that it is no longer working with instances. I’m trying in every way.
I’m on win 10 - Cinema 4D 2024.4.0 - V-Ray 6 for Cinema 4D, update 2.3 (v6.20.03 from Jun 26 2024)
I attach the example scene if it helps
For now I’m back to the previous build (V-Ray 6 for Cinema 4D, update 2.2 (v6.20.02 from Apr 12 2024) and it works as it should
thanks​
uvw_randomizer_problem.c4d (333 KB)
Hi @visualtracing , currently the “Random by Instance” mode works only for Cloners in Multi-instance mode. We have logged an internal issue ( VC4D-2358 ) to improve this option to work for the Instance object and for Cloners in Instance and Render instance modes.
With 6.20.03 we hid the “Random by Render ID” option, because it does not produce stable render results. This means that using the “Random by Render ID” option, may lead to the scene rendering differently each time it is opened in a different Cinema 4D process.
We will write here when there is progress on the issue.
