I’m not sure if this is a bug or technical limitation, but pluging same bitmap to multiple UVW randomizer nodes with different seed and then comping those nodes in composite or Corona mix node, the end result is wrong. However if i plug copy of the bitmap, it gives correct result. See attached images.
Fixed, will appear in 1-2 dailies from now, watch out for changelog
Thank you very much!
