Hi, so i want to use the random uv rotation on a wall of hexagonal tiles. I have randomise by element set, and it rotates ok, but it seems that its not rotating from the center of the uv tile. Im not sure if this is what i should expect or not? If not, maybe an option would be good? I get that maybe this is an edge case but I thought i would ask.
So this is before rotation
Rotating 90 using UVWrandomiser W value (no randomisation active)
And this is when i use 0-90 step 0, randomize by element.
NOTE: ive just used 90degree value in the images as an example that shows the issue a bit clearer, I actually was hoping to use values of 0-360 step 6, to rotate the uv from the center at 60deg angles.
Scene attached.
Max 2024
Vray7 gpu
recommended drivers.
UVWrandomizer.zip (103 KB)
