V 6.2.02, V-Ray Scatter Objects are not in Rendered View, but shows in Interactive
Hello, I’m having an issue where the v-ray scatter objects will show up in the interactive view but not in the rendered view. I have V-ray 6.2.02. This is rendered locally. I’ve closed, cleaned my temp memory. Restarted computer. Also an issue with cloud rendering. Not sure why this is happening since the individual assets from cosmos are showing. See images below. The rendered view shows the gpu, etc. if that helps. Your quick assistance is much appreciated. Many thanks.
Hello @joel_mccullough ,
Thank you for your post.
For now I was not able to reproduce this issue in the new scene. Can you please also try creating a new Scatter with some Cosmos assets in the new project? Does it work on your side?
If yes, please try two options in your current scene:
  • Clear guest objects from the Scatter and reassign them again;
  • Another option is to delete and recreate Scatter.
Let me know if any of the above help.
Also please share your exact Rhino version (example).​
Hello Natalia,
Thanks for the response. I made new scatter objects and it rendered fine. Thanks for the suggestion! This is on Rhino 7 SR36 2023-12-12.
