V-Ray 1.5 SP5 for 3ds Max is now available for download from our site at http://www.chaosgroup.com/
This build provides compatibility with 3ds Max 2011 and 3ds Max Design 2011; the changelog is as follows:
V-Ray/Max - 1.5 SP5 official (6 May 2010)
New features:
(*) Added VRaySamplerInfoTex texture and VRaySamplerInfo render element;
(*) Added VRayObjectSelect render element which allows to extract objects with specific IDs into a separate element;
Modified features:
(*) Added an option to the VRayPhysicalCamera to perform image distortion based on a texture map;
(*) Allow ther user to specify texture bounds for 3d displacement;
(*) Added displacement slot to VRayFastSSS2 material;
(*) Added “prepass id” parameter to VRayFastSSS2 material so that multiple materials can share the same illumination map;
(*) Added displacement slot to VRayLightMtl material;
(*) The color parameter of VRayIES lights is now animatable;
(*) The min/max z-depth values for the VRayZDepth render element are now animatable;
(*) Support for reflection occlusion in VRayDirt;
(*) Support for environment sampling in VRayDirt;
(*) Support for Particle Flow vertex color mapping and particle visibility;
(*) Support for the “Use transparent shadows” option with Arch&Design materials;
(*) The clipping planes for the VRayPhysicalCamera are now displayed in the viewport;
(*) Added an option “show cone” to the VRayPhysicalCamera to control the display of the camera in the viewports;
(*) Ability to save and load color correction curves for the VFB in Adobe(r) PhotoShop(r) .acv format;
(*) Support for pixel aspect ratio display in the V-Ray VFB;
(*) Support for anaglyph stereo preview in the V-Ray VFB;
(*) Support for LUT color correction in the V-Ray VFB from .cube files;
(*) Ability to display the value of the corrected colors in the V-Ray VFB pixel info dialog;
(*) The “Dynamic memory limit” parameter can be set to zero to remove any limit;
Bug fixes:
(*) Motion blur for Hair&Fur in “mr prim” mode does not match the “buffer” mode;
(*) Occasional random crashes in 3ds Max 2010 due to progress bar updates;
(*) Fixed invalid smoothed normals causing issues with displacement;
(*) Fixed AA artifacts with thin bright lines when using Adaptive DMC image sampler;
(*) Stuck buckets with perfectly transparent surfaces and GI;
(*) Incorrect vignetting for VRayPhysicalCamera when using horizontal/vertical offset;
(*) setVRaySilentMode() should disable the dialog for overwriting raw .vrimg files;
(*) Missing reflections in VRayFastSSS2 when it is a coat material inside a VRayBlendMtl;
(*) Incorrect bump mapping for GI when using time-interpolated irradiance maps;
(*) Fixed artifacts with VRayFastSSS2 when one of the scatter color components is zero;
(*) Fixed incorrect normal map with VRayNormalMap on VRayProxy objects;
(*) Fixed crash with animated irradiance maps and objects with zero scale;
(*) The color of VRayIES lights was not animatable;
(*) VRayIES lights did not produce photon-mapped caustics;
(*) Fixed invalid normals with VRayEdgesTex in the bump slot;
