Which one? Some of those features are in the Maya release already (f.e. GGX, VFB stuff, Embree for proxies).
I would be very happy to have subsurface scattering and refraction fog for RT GPU in Maya :).
Ah that. I actually think the SSS might be there, but I need to check.
You mean the Fast SSS2 material or the subsurface scattering tab in the Vray Mtl? And by saying it might be there, do you mean by that that it might be in the current nightlies or already in the current build? In any case, thank you very much for the taking the time!
Best
Martin
I can confirm that FastSSS2 material is already supported on the GPU in our internal builds.
Subsurface Scattering of VrayMtl and SkinMtl are not supported yet.
I’m probably missing something, but… What’s the workflow for using VRayInstancer? I couldn’t figure out how to use it… (feeling kind of dumb)
Here is a simple example - let me know if something is not clear.
vrayinstancer.zip (26.7 KB)
Hum… got it! You can’t have any instances on the PFlow… Thanks, Vlado!
Thanks for this Chaosgroup. Looking forward to testing the GGX shaders.
Hey Valdo,
Like the Opacity modes, the Two sided material, and there are other little stuff, vray instancer, vray clipper … are they in the nightly builds?
Hey wow. In my first test, the VRayInstancer kicked Multiscatter’s ass for rendering a forest of 20,000 trees. The “Updating Instances” stage took a little while but in the end it was nearly twice as fast.
…and upon further experimentation, if you use VRayProxys instead, you don’t have to wait for the Updating Instances, but the render takes nearly twice as long. Still slightly faster than Multiscatter, though.
Anyone want to see how it compares to ForestPack?
Wow, this is a nice update, loving it (esp. the new GGX Shader and overall rendering speedup).
I really would get my hands on that Chaosgroup logo scene with the ice material.
Vlado, is in this vast universe the smallest single possibility you would share it? ![]()
Thanks to Chaosgroup for this SP1 release; I regard is as a huge x-mass gift!
Cheers
Ale
I would love that scene as well ![]()
I wasn’t even thinking that vray instancer could replace somehow the instancer plugins!
I’m curios to see some comparisons.
yes it happened with me too, on vray 3.00.08.
It looks like a 3DS Max limitation. Referenced scenes are rendered in Isolation mode even with the native scanline renderer.
Hey there, i can´t update right now, but I´m very interested in the Vray Instancer. Since I also couldn´t find the documentation for it, maybe you could answer me some questions:
I´m working on a scene right now, where I need to render about 100-500.000 Particles I´m scattering on the floor. The objects are around 500 verts each. But everytime I try to render, my memory starts maxing out and the render fails/crashes.
There is probably a way to limit the amount of particles to the ones actually seen in the camera view, but I´m not advanced enough in Pflow to do that…
So…
How does the instancer work?
Right now I´m using a shape instance operator in my Pflow, which is picking a group of different objects to scatter.
Can I use the Vray Instancer to achieve a renderable result?
Pflow was never properly updated due to autodesk being rather silly people and it hasn’t been updated or optimised since the start. What you can do in pflow is in the very first event in your flow, there are options to choose how it calculates the geometry to render. You can dump out one large mesh for the lot, a series of meshes each containing a certain amount of polys, or a single mesh per particle. If you’re got a shape instances with a lot of polys and tonnes of particles, trying to calculate one great big dumb mesh can be a bit nasty memory wise so it can be slow and somewhat unstable, mesh per particle can be a bit faster to process. The issue still remains that particle flow is generating a lot of mesh to hand over to vray who can then start to render the polys. With the vray instancer, you can keep your particles with no shape at all and just use the various transform, rotation and scaling calculations so it doesn’t have to handle the geometry side at all. Vray is taking over in the generation of the actual polys and it can do this in a far more efficient fashion with everything being properly multithreaded. If you’ve got memory worries then you’ve the option of using proxys as the instance at the expense of performance, otherwise you can use normal geo as your instance and get lots of speed options. One caveat is that you lose the option of changing the shape of a particle in different events though no doubt this’ll get added in as time goes on.
Yeah, Autodesk beeing slow is the main reason I´m spending so much time here in these forums…![]()
I´m still not quite sure how the vray instancer handles geometry from my Pflow: Does it actually replace all shape instances with the according shapes, but as proxies/instances? Or do you have to pick one object (like a proxie) as an instance and tha instancer replaces all shape instances with that one? the later case would mean I couldn´t use it, since I couldnt´pick multiple objects as instances.
I already used the “mesh per particle” option,even though I don´t consider 500 verts “Hipoly”, but still: 200.000x 500 verts is still a lot to process…
