We’ve just released a new update to V-Ray for Maya 3.5!
Here’s the list of bug fixes in 3.52.03 since 3.52.02:
Bug fixes:
(*) VFB: Fixed unresponsive UI with OCIO and IPR;
(*) VRayMtl: Fixed wrong SSS with glossy Fresnel enabled;
(*) VRayMtl: Fixed missing GI from self-illumination with glossy Fresnel enabled;
(*) VRayMtl: Fixed wrong alpha with mapped opacity and glossy Fresnel when seen in reflections;
(*) VRayAlSurface: Now works with VRayLightSelect;
(*) V-Ray IPR: Fixed a crash with light linking;
(*) Texture Baking: Fixed crash when baking multiple objects;
(*) V-Ray: Fixed a problem when creating output image directory in limited access situations;
(*) V-Ray: V-Ray will no longer add an “rs_” prefix when using Render Setup with 2017 update 3;
(*) VRayMesh: Fixed a crash with Alembic file with no UV topology channel;
(*) VRayFastSSS2: Fixed SSS surface ID not working properly;
(*) VRayFur: Fixed wrong visibility in IPR when the base object is hidden;
(*) VRayScene: Fixed wrong display of vrscenes in the viewport;
(*) V-Ray GPU: Fixed BlendMtl not rendering with OpenCL;
(*) V-Ray GPU: Fixed failing OpenCL compilation on Linux;
(*) V-Ray GPU: Fixed wrong UVs on bitmaps with driver versions 380 and up;
The builds are available for download on the Chaosgroup website.
Mihail Djurev,
V-Ray for Maya Team Lead
