V-Ray 3.6 Hybrid GPU on Render Nodes
My workflow is that I send DR jobs to Backburner for processing. With that said, is there any advantage in installing quality GPU’s in the Render Nodes?
Thanks.
The hybrid rendering basically makes V-Ray GPU CUDA being able to use CPUs as well. If you are not using V-Ray GPU (but V-Ray Adv / CPU rendering, no point in adding GPUs to the render nodes.
Best,
Blago.
