V-Ray 3.6 VFB hangs
ok made another test stable build Vray 3.50.04 and 3ds max 2018.2
VFB update is also not working !!!
>>>important: when i minimize max incl. VFB and maximize it again VFB gets updated.
so it seems that 2018.2 (the update) is related to the problem
vray 3.50.04 - max 2018.2 - win 10 - xeon dual processor
and
reinstalled max update 2 and Vray 3.60.03
not working
vray 3.60.03 - max 2018.2 - win 10 - xeon dual processor
hope that helps
Hi Vlado, I have created the dump file, but it is almost 1gb, it is ok? I will send it to support
Thanks!
PS: My issue is a bit different because the render at the end is complete, is just that in the process the VFB is completely stucked and is like it doesn’t update until it is finished. I tried modifying the affinity without luck. Hope the dump file helps to give you an idea of what’s going on :slight_smile:
PSS: here is the dump file link Unique Download Link | WeTransfer
one more info
i just upgraded one pc (singl processor) from max 2018 to 2018.2 and vray 3.60.02 to 3.60.03
everything works fine !!!
so it seems that i have no problems on single processor pcs but on xeon dual processor
the pc that does not work fine with 2018.2 and 3.60.03 is my workstation:
xeon dual processor - 32 GB RAM - win 10 latest - 3ds max 2018.2 - vray 3.60.03
VFB does not update
3ds max 2017 with vray 3.60.03 works fine on that workstation
Here is happens on single processor Core i7 5930K
that ruins my theory
any chance to see a solution for that problem
or any work around ?
did the 3ds max dump file help ?
Tried to do some dump, but always got error process.readmemory …
While bucket rendering, if we hit render and don’t touch anything, we can see the render … rendering!
I we touch a window, vfb become white and windows are flashing here and there until render end.
Really really hard to produce with such behavior
so i did a last try
deinstalled everything completely:
reinstalled max 2018 - updated to 2018.2 - installed vray 3.60.03
the problem is still here
VFB will not update !
opened up 2018 again
imported a just created scene
>>> told the phys camera to install exposer control - i had to do so !!!
hit render
hit interactive render - just for fun to see its not working
but:
now it suddenly works for me !!!
may be that helps
There is also serious problems with backburner rendering.
The 3dsmax process takes so much process that nothing else can do anything. So server.exe doesn’t get answer, and launch several (sometimes dozens!!) of 3dsmax and maxadapter and the computer just get stuck. We can just rdp it, even keyboard doesn’t respond, I’ve made a bat to kill all maxadapter, 3dsmax, server so the machine can finnally respond.
Even with max process as low priority and low priority thread checked, V-Ray takes all single processor loop. Nothing can run beside when max is rendering. Never had this with V-Ray before 3.6x
I would like to add we have the same problem on our Dual Xeons using MAX 2018 Vray 3.60.02, hope this one can get resolved.
The VFB, and entire machine for that matter is completely unresponsive for most of the rendering time, on occasion you can get the mouse to respond to do things very slowly
--update
The issue only seems to show up in bucket mode. Progressive seems to be unaffected
same here
i7 6800K, max 2018 sp2, vRay 3.60.03
I’m also having same issue. Seems in can happen just about anytime but mostly with high res 5K renders using DR.
max2018 sp2, Vray 3.6, Win7Pro, dual Xeon.
I’ve found that locking Windows for a minute and then logging back in can sometime break the spell and bring the VFB back.
Same issue here. Max 2018 sp2, Vray 3.60.03. Win 7 pro , Dual Xeon V4.
Max 2016. worked flawlessly on the same machine.
Update:
3.50.04 under 2017 appears to be ok on our Xeons
3.60.03 under 2018 SP2 WIn 10x64 1703 completely hoses my workstation, have to cycle power to get it back in same scene
Doesn’t seems to be related to max version, but since VRay 3.6.x
Have similar problems with MAX 2016 + Latest Vray + Dual Xeon CPU
encountered frozen max after cancelling render yesterday. took good few minutes to come back. tried that like 4 times with the same result.
win 7, max 2015, vray 3.60.03, DR, double xeons.
thing is that scene is working just fine on second identical pc, no freezing whatsoever.
its totally average arch viz scene, nothing extreme.
I have done a complete format to go back to Windows 7 Pro (from Windows 10), and the problem persist.
Windows 7 Pro
3dsmax 2018.2
Vray 3.60.03
Edit: IPR doesnt cause the same hang
@vlado , did you find something ? Seems multi-threading since 3.6 is a bit too… strong oO
I did some test, and for me it becomes unresponsive even when rendering locally. If I’m already in the VFB and don’t open any correction tabs, I can navigate the VFB, but as soon as I try to switch render pass/channel or open i.e. WB it completely hangs and becomes responsive only after the complete image is finished. It’s even worse when rendering in DR. I just did a test with a simple plane + teapots and It becomes completely unresponsive. The “low thread priority” option is always checked. I’m working on a machine with a total of 56 threads, and by the end of the rendering process if only half of the buckets are still active, the VFB/max is working smooth as it should.
Is there any fix on the horizon?
