V-Ray 3.60.02 bugs
1. Materials cannot be deleted from the Material list by selecting them and pressing Delete key.
2. In many situations, adding a material from library to the Material list does not select it in sketchup, so it cannot be applied on a surface with paint tool. Like in this video: https://youtu.be/Kt-DKhupy\_E
3. When saving a render, presing the Save button opens the browse window behind the rendering window.
4. V-Ray asset editor window does not save it`s size and location between uses. Every time I start Skethcup I have to drag it and expend it (4k monitor).
Thanks!
Hello, Isarescu, and apologies for the late reply!
1. This is intended behavior. We will be revisiting the keyboard shortcuts for the next major update, including the use of ‘Delete’ in the Asset Editor.
2. Will look into it. As a workaround, simply right-click on a Preset Material from the library and use ‘Apply To Selection’.
3. We are aware of the inconsistency of file-picker windows’ focus the first time they are opened. A ticket is already being logged, although I cannot advise whether a solution will be included in the upcoming v3.60.03 or later on.
4. Currently, such data is not preserved between sessions. This may be partially improved down the road. For now, it was determined safer for use and implementation to have the UI restored to default state on each session start.
Thank you for your feedback!
Kind regards,
Peter
