I’m rendering an animation via backburner and have my final output dialed in with a bit of a curve adjustment. I just noted that my rendered framed are not saving with the curve adjustment.
Is it this possible to save them with the curve adjustment?
It looks like for the moment this only works if you save through the VFB itself (f.e. the “split render channels” option). I’m not sure if things always worked this way - I seem to remember that the curves were saved through the normal renderer output too. Need to look into it.
