V-Ray 5 for Cinema 4D - Hotfix 2 is now available
Hello everyone,
V-Ray 5 for Cinema 4D - Hotfix 2 is out
This is mainly an improvement and bugfix focused release. Thank you for your feedback and reports.
The builds could be downloaded from the Downloads section on our site.
Here is the change log for this release version 5.00.44
Improvements
  • VolumeGrid Preview Rollout for Cinema 4D - Velocity Streamlines
  • Integrate V-Ray TexRamp texture
  • Support for Cloner object with V-Ray Volume Grid in Cinema 4D
Bug fixes
  • Distributed rendering doesn’t work correctly when rendering animations
  • Wrong material assignment on objects with dynamic caches
  • HairNextMtl doesn’t work with UVW Mapping projection
  • Materials get tiled when scaled even if “tile” setting is disabled in Attributes manager
  • Image sequences are not rendered when used with the Cinema 4D bitmap
  • Cinema 4D noise doesn’t work when used in Blend Material
  • Relative file paths do not work for non-texture assets
  • Deformed geometry does not update in animation
  • Motion blur only works for the first rendered frame
  • The Distance texture is not affected by geometry with applied skin deformer
  • Crashes on macOS systems with more CPU cores
  • Cloning Proxy objects doesn’t copy the assigned materials
  • Animated visibility of objects does not work
