I am attempting to use the exercise files from this course:
The scenes were created in V-Ray Next. When I try to render in V-Ray 5 GPU Hotfix 2, I get a fatal error. 3ds Max instantly crashes. The V-Ray Message window pops up for a split second, not enough time to actually read it. I think it might have said something about Fast SSS.
I tried Merging the scene instead of opening it directly. Same result. It does appear that there is some major incompatibility between V-Ray Next and V-Ray 5 GPU, causing repeatable fatal errors.
Can you let us know if you get any warning/error messages in the V-Ray log and if so, what are they exactly? Have you updated your GPU drivers to the latest recommended ones? Are the scenes rendering as expected with CPU?
@aaron_ross , have you tried getting the latest update for V-Ray 5 for 3ds max? You can download it from here. Alternatively, we will need a stripped down version of the scene with the issue reproducible so we can have a look and troubleshoot.
@TIWO_Design - the same applies - any details and screenshots/screen recordings would also be greatly appreciated.
If you are able to forward us a scene, make sure to get in touch with us via our contact form and mention this thread in the email, thanks! Please also provide details regarding your OS/CPU/GPU/GPU driver configuration.
