Hey guys,
V-Ray 5, hotfix 1 is now available for download from our website.
I’ve highlighted some important things.
Build 5.00.04 (V-Ray 5, hotfix 1) (14 July 2020)
New features:
(*) VRayBackToBeauty: Add render element that will expand to all beauty render channels;
Modified features:
(*) V-Ray: Simplify the Image sampler options;
(*) VRayBitmap: View image button should work for .tx bitmaps;
(*) VRayDistanceTex: Add an option to not compute for the viewports;
(*) VRayMtl: Raise the default Refraction and Reflection Max depth to 8;
(*) VFB2: Add keyboard shortcut for Lock Pixel Coordinates (“L”);
(*) VFB2: Support for the color corrections and VRayDenoiser in V-Ray Viewport IPR;
(*) VFB2: Zoom key combinations support;
(*) Installer: Progress of V-Ray Material Library download should display downloaded/total size in the installer;
Bug fixes:
(*) V-Ray: VRayDisplacementMod’s Subdivision not working far from scene origin;
(*) V-Ray GPU: Activating 3ds Max menus during IPR stops image updates in the VFB;
(*) V-Ray GPU: Memory leak with VRayDistanceTex;
(*) V-Ray GPU IPR: Orthographic projection is not rendered properly with RTX;
(*) VRayClipper: Wrong objects in the exclude list when merged in scene;
(*) VRayLight: NaN pixels occur with textured adaptive dome light;
(*) VRayToonMtl: Overlapping MaxScript names of gradient parameters;
(*) VRayTriplanarTex: Incorrect motion blur;
(*) VRayVolumeGrid: More noise with Blue Noise Sampling enabled for grid volumes;
(*) VFB2: Artifacts with Filmic tonemap;
(*) VFB2: Colorful halo with Lens Effects and positive Lightness values in the Hue/Saturation color correction;
(*) VFB2: Crash on consecutive V-Ray GPU IPR restarts when selecting different layers;
(*) VFB2: Crash on scene open when the scene was saved with legacy VFB LUT color correction;
(*) VFB2: Different convert to composite result if the first light is turned off;
(*) VFB2: Large color values are not formatted properly in pixel info;
(*) VFB2: Missing color corrections/post effects on image copied to clipboard;
(*) VFB2: Resize on region IPR when an image has been previously loaded from history;
(*) VFB2: Show corrected colors doesn’t work;
(*) VFB2: Switching from OCIO to sRGB and back loses the OCIO settings;
(*) VFB: “Too many open files” error when loading many LUT files;
(*) VFB2: Window position can not be saved on a non-primary monitor;
(*) Installer: Downloading the V-Ray Material Library does not work with network paths starting with “\”;
(*) Installer: The install log is empty when an error occurs;
